Adding to variable checkbox tick problem
November 3, 2006 12:00 AM
Generally, you need to check the value of the variable that is being set by the check box on the condition tab. I can provide a more specific solution if clarify your request: Please supply enough information for us to help you. 1. Are you using check boxes from a question of some kind or form check boxes? They give radically different values to their variables.2. What does "load a variable with a number checked" mean? Are you referring to the the check box? Where is the variable getting loaded? What do you mean by load? Do you mean Set to a constant? Adding 1 as you stated in the first paragraph? Or set to the value of another variable? Generally loaded refers to retrieving something from disk or down the wire such as loading a page from the disk or from the server or loading a variable from the last session (from cookies which is handled by Lectora).3. Where do you currently have the action that adds 1? Is it on the On Select/Change tab? Are you checking all the boxes when someone clicks a button?4. What version of Lectora are you running? A 2006 version will be quite different from a 2005.
