Matching Question Issues - Completely not working
Karen,
Are you publishing the content as an .exe, to cd, or html (aicc or scorm)? If .exe or cd, there may be no other way except to get rid of the background. If html (aicc or scorm), you may be OK. Try preview in browser with everything inherited to the page, does the question work then?
One other possibility that you could try is, on the page with the question, try removing the green colored background graphic, and just change the background of the page, in the page properties, to the green color. Worth a shot if you are publishing to .exe or cd.
I was having the same issues, luckily we publish to html (aicc) and I didn't need to change anything.
Good Luck.
