HELP! Trigger Completion Status with course that does not have a quiz
July 8, 2009 12:00 AM
I would check with the LMS tech support and see what value they look for to register a completion. Some use completed, while others use complete, or others use C, or passed.
With the actions you have listed, the value is getting sent to the LMS, but the LMS probably doesn't know what to do with it.
tarab said:Hello all! I am ready to pull my hair out! This is frustrating as I have tried everything that I think would work. Anyway, I am using Lectora 9 with an LMS called Aptify. I have a super basic 5 screen course with no quiz. I need this course to trigger a completion status and "passed" or "success" status in the LMS. I have checked out all of the previous posts and done everything that has been posted but I am not getting the results that I need. I have three actions on the last screens Close btn. On click Modify Variable AICC_Score 100 Set Variable Contents On Click Modify Variable AICC_Completion_Status completed Set Variable Contents On Click Modify Variable CMI_Completion_Status completed Set Variable Contents Any insight that anyone has would be fantastic. Thanks!
