Font problems
Here are some additional thoughts on trouble shooting:1. Change your resolution to 800x600 and see if you can duplicate the look, assuming your resolution is higher. Do you have a standard resolution for your users?2. Using your original resolution open a new browser and go to – view, text size, and select something smaller than you are using. 3. Are you using the “size/position locked” in the text properties?4. I have had the same issue with text that is “aligned right” and the list of terms that was also “aligned right” – the only way I worked around it was to publish the text as an image and the cured the alignment issue. I5. If the original content comes to you in PowerPoint and you are using the “Integrator” that could be part of the was you setup the ppt file before importing. If this is the case respond as a “buddy” and I will give you more detailed information.
