Flash prventing images from showing
lucash, I am having the same problem as well. We have a flash menu that slides out over images. We have used this before in previous modules with no problem, but this time we are getting a lectora variable into the menu itself so it unlocks as the user progresses through the content. The Flash 'wmode' parameter is set to 'transparent', set to always be on top, with auto-start enabled. The images are set to the bottom layer. What happens is that random top portions of the image appear, or sometimes even not at all. If you right click the image and choose the 'show picture' option from the context menu, it appears in its full glory.I haven't tested this online but only from a networked drive at work. Is this a bug in Lectora 2007?
