Table of Contents problem
March 20, 2007 12:00 AM
In my new template I have created a "course map" page which is essentially just a page with a TOC element. Clicking a "map" button within the course will save the location of that page and then direct the user to the page with the TOC element. Pressing "back" on that page will take the user back to the page on which they clicked "map".This all works fine when I am running the HTML files locally. When I put them on our network and run them, however, the TOC element is very inconsistent as to whether or not it chooses to appear. Sometimes it appears perfectly intact, sometimes the frame appears without any content (within which one can right-click and select Refresh to make the content appear), and sometimes nothing appears at all. There does not appear to be a rhyme or reason to when it appears and when it does not.I have tried making the TOC initially invisible and putting a delay on the show command, to give it some extra time in case the scripts are slowing it down. I have tried removing all other images and nav buttons from the page. So far, nothing I have tried has affected this problem.We're using Lectora 2005 - anyone have any suggestions?
