Exit Title/AICC_Lesson_Status problem
February 19, 2008 12:00 AM
I'm trying to create a course that on the final page has two button choices- One to indicate that you understood what you read and one to indicate that you didn't. The understood button has to perform to separate actions:1. Modify the AICC_Lesson_Status to completed2. Exit Title/Close Window.I can't get this to work. The exit title action seems to overtake the modify AICC_Lesson_Status action. When I take the Exit Title action off of the button, the AICC lesson status works just fine, but I need the button to do both.Does anyone have any advice?
