streaming audio not playing
February 20, 2008 12:00 AM
I too am having the same issue. I have successfully installed the Streaming Server, and it works fine with .wmv files, but when I use .mp3 or even .wav files, the CONTROLLER doesn't even show up when I link to the audio files. This controller is mandatory if using Streaming Audio.This is odd. I tested the audio,and it works fine, but when hit preview in Lectora, the controller doesn't even show up and no audio.Trivantis peeps, can you assist if / and how to get Streaming Audio to work in Lectora.I am using 2008 with all updates.Cheers
