Drag and Drop Questions
January 12, 2010 12:00 AM
I'm new to Lectora and may be off here, but in the short time I have used the new Lectora X, I encountered a similar problem with the drag and drop in developing my first course. It seems the drop point is always the same size as the selected image or text block. In my case I made a work-around with the images by re-sizing/scaling them to the drop area's size. With some of them I added a sized, transparent background to the images so they drop in a larger spot. Hope this info is relevant!
beachgirl said:Is there a way to make the drop point bigger than the dragged image I am using. In my case, I want the user to be able to place an image on a timeline - it can be placed in a pretty big spot on the timeline and the image is pretty small.
