Course hangs after feedback problem
Hi thereI was very interested in this thread. We use Lectora 2006 pro suite, and we recently (couple of months ago) downloaded SP2. Since then, if we publish files at work, the tests either won't load at all or the results aren't shown to the user. However if we publish on laptops - all works fine. This has only happened since SP2. We contacted support and they couldn't replicate the problem. We use IE6 with sun java. I'm sure it's something to do with permissions - our systems are so locked down we almost need a business case to open word!! As you can imagine, I'm very interested in finding out what caused this and a way to fix it.
