Course hangs after feedback problem
Hi Tory, That's an interesting idea I'll look into, but you'd think if it were a blocker the results would/should be consistently halting. We do have feedback turned on, that is the window we are experiening the problem with, but only sometimes. And after that if you use task manager and kill explorer, re-enter the course, it doesn't occur again until we believe is the next reboot.Hi Tory, That's an interesting idea I'll look into, but you'd think if it were a blocker the results would/should be consistently halting. We do have feedback turned on, that is the window we are experiening the problem with, but only sometimes. And after that if you use task manager and kill explorer, re-enter the course, it doesn't occur again until we believe is the next reboot.
