Course hangs after feedback problem
May 23, 2006 12:00 AM
Our solution in the end was to publish with javascript titlemanager so we no longer use Sun Java. This has meant also creating various ASP scripts in order to submit results via CGI. We now have over 4000 completions with this method and not one freeze, where as our courses that are still using Sub Java still continue freezes whenever the hell they like!Our solution in the end was to publish with javascript titlemanager so we no longer use Sun Java. This has meant also creating various ASP scripts in order to submit results via CGI. We now have over 4000 completions with this method and not one freeze, where as our courses that are still using Sub Java still continue freezes whenever the hell they like!
