check answer group help!
Too hard for me to figure out without seeing. Suggest you post a version on the LectoraExchange.org under Problems section and let us know here. Use File menu > Export > Zip to create the zip file to post.Too hard for me to figure out without seeing. Suggest you post a version on the LectoraExchange.org under Problems section and let us know here. Use File menu > Export > Zip to create the zip file to post.
