pop up problem
May 8, 2007 12:00 AM
Yikes!?! Make sure the Exit/Close action is on your continue button in the PopUp and not in the main content. I'm not sure if that's the case at all...but just as a precaution. Also, make sure the action to set the variable is on top of the Exit/Close action.Yikes!?! Make sure the Exit/Close action is on your continue button in the PopUp and not in the main content. I'm not sure if that's the case at all...but just as a precaution. Also, make sure the action to set the variable is on top of the Exit/Close action.
