pop up problem
May 8, 2007 12:00 AM
Ok. Well, it is a working example. The delay can be cut to .1. I use the delay to keep it from sucking up all the cpu time.Ok. Well, it is a working example. The delay can be cut to .1. I use the delay to keep it from sucking up all the cpu time.
