Advice on building a web site w/ Lectora
October 9, 2007 12:00 AM
The simplest way to do it would be to use chapters, sections, etc. Make sure the top level properties are set to Standard Lectora Title, this way you can liink between the various levels. When you have designed it publish to html. Please let us know how it turns out.The simplest way to do it would be to use chapters, sections, etc. Make sure the top level properties are set to Standard Lectora Title, this way you can liink between the various levels. When you have designed it publish to html. Please let us know how it turns out.
