Required Question (not inTest)
May 29, 2008 12:00 AM
I take it that you do NOT want the questions to be part of a test otherwise you could put the content and the questions in a Test type chapter rather than a regular chapter. Given that, best I can think of is to have two buttons:Check My Answer which processes the question or checks the variable for correct. If correct, it shows the Next button.The Next button which is hidden or grayed out until it is okay to click it.Done usually comes at the end of a test. What do you mean by it here? i.e. What actions does it do?
