Advice on building a web site w/ Lectora
If you have less than about 100 pages, one title will work fine. If you structure it as chapters, sections and sub sections, then you can use a table of contents as well as your own custom built menus. There are a couple of limitations when using Lectora for a web site that are not normally expected by web user.1. the pages don't squish - they text blocks will not adjust in size as the page is made bigger or smaller. 2. The font in the text blocks is not adjustable. Normally the user can go to the browser View menu and change the Text Size. That option has no effect on Lectora pages as the font size is fixed. This is especially important if you are dealing with people who might be visually handicapped.
