Login Sign Up
ELB Learning Logo
Topics
Members
Website
Knowledge Base
New Topic
Menu
  • Topics
  • Members
  • Website
  • Knowledge Base
  • New Topic
Archived
Report Abuse
variable default values
@tfones
May 19, 2007 12:00 AM
It may not be the default value, it may be the test for zero or non zero. I found a problem with tests for zero in 2006. Have not retested in 2007. It may not be the default value, it may be the test for zero or non zero. I found a problem with tests for zero in 2006. Have not retested in 2007.
tfones tfones
@tfones
View Profile
More From tfones
Flash Play & Pause button
June 5, 2008 Reply 0 Upvotes
Tracking for executable file
July 7, 2007 Reply 0 Upvotes
Image Properties when adding to page
May 11, 2007 Reply 0 Upvotes
appending text to variables
May 8, 2007 Reply 0 Upvotes
Capturing test results
March 30, 2007 Reply 0 Upvotes
Join The Discussion
Sign Up Login
