Using .Wink. screen capture
Good points Ludo.I use Adobe Captivate for software simulations and soft skills presentation, and usually set the screen size at either 640x480 or 800x600 depending on the size I set in Lectora. Setting the screen capture at a large size allows for resizing that keeps the sharpness of the simulation.Because Captivate is in Flash then should retain the clarity of the simulation.Hope this helps.
