Using Transitions & Actions together
If I'm understanding correctly, box one will transition out at 7 secs (when box two transitions in triggering the "on show, hide" action) + 5 secs (the delay set when you set the transition out on box one to 5 secs). Box two will transition out at 13 secs + 11 secs for the same reasons.I'd suggest taking out the "transition out" settings and trying it.
