Using Transitions & Actions together
January 30, 2007 12:00 AM
THANK YOU BOTH!!! I KNEWit had to be something very simple I was overlooking.I was obviously not thinking in the proper direction of logical terms, and probably because I was trying to get the transitions to work without a separate action (simply having the object transition in at X seconds and out at Y seconds based on it's own properties) and when I realized I had to add the action, it didn't occur to me that the "out" time would add on to the action's timeframe.This is great, and thanks again!!!
