Transparent Flash
February 1, 2007 12:00 AM
Hi Mel,I'm still struggling. Bear in mind I use Lectora 2005 at the moment, so that may be limiting my choices. What version do you use?Here's my problem. After adding the .swf file as an animation to my title, when I right click on the animation and select 'Properties' I don't get a choice called 'Parameters'. The five tabs I can choose from are:GeneralSize/PositionFly in/fly outReferenceMetadataOn none of these tabs can I find anything to do with Parameters. Any suggestions?
