Transition problem
The transition setting doesn't cause the object (your text) to appear or disappear. It only affects how it transitions in or out. You have to create an action to show or hide the object. It's only transitioning in (showing)because you have the "initially visible" box checked.Try adding an action to your text box. For this example, it could also be put on the page as well. On "Show" "Hide" {your text box}. I personally would set the delay on the action rather than the transition, but either way should work.
