Flash Issue
Since the video is a .swf file Lectora won't add any video controls to control the playback, like it would if you were to just add a video. By default flash will keep looping the video if there are no actions to stop it. It is possible to build controls in flash and have them load in the .swf, and use them to control the playback. So you may have to build your own controls. There are some actions in Lectora that control animations you might try some of those. If they don't work you can send me the .swf file and I have some controls I could customize to run the .swf and send it back. Either way let me know.Since the video is a .swf file Lectora won't add any video controls to control the playback, like it would if you were to just add a video. By default flash will keep looping the video if there are no actions to stop it. It is possible to build controls in flash and have them load in the .swf, and use them to control the playback. So you may have to build your own controls. There are some actions in Lectora that control animations you might try some of those. If they don't work you can send me the .swf file and I have some controls I could customize to run the .swf and send it back. Either way let me know.
