Tracking Issues using multiple SCO's
June 28, 2005 12:00 AM
The SCOs are strung together in the publishing process. In Lectora 2006, you can edit the prerequisites for each individual SCO (thus setting a predefined order or no order at all). In an LCMS (if that is what you are publishing to instead of a straight LMS), you can create your own courses by using the catalog and putting your owns SCOs together. As Aaron said, if you want them to go through in any order and you are using a pre-2006 version of Lectora (or any other authoring tool), just create all your SCOs, generate your manifest by publishing, and then remove the adlcp:prerequisites tag which sets the order.TimEdited By: Verrelli on 2006-2-21 22:4:58
