Tracking Issues using multiple SCO's
The prerequisites are defined in the SCORM manifest file. You could manually remove the prerequisites yourself. Just publish out to SCORM and open the imsmanifest.xml in a text editor such as Notepad. Remove the line I_A002 that is under each for every SCO within the course. Save the file and now import the course into the LMS and the students can take the SCOs in any order.Edited By: aaron on 38531.6861458333
