Tracking Issues using multiple SCO's
June 28, 2005 12:00 AM
Then you are using a non-compliant LMS. By definition, an Assignable Unit / Shareable Content Object is a self contained entity. It does not know anything about any other AU/SCO. The entire concept of re-usable content is based on individual content objects that stand alone ... but I, as a course creator can take a bunch of them and string them together to create a course. If any of them have external dependencies on other objects, then they MUST be contained within that content otherwise I couldn't just string them together and give them to someone else for loading into a different LMS ... the content wouldn't run.Tim
