Text alignment problem in Lectora
February 3, 2010 12:00 AM
There is no good way to paste and get the format of the copied text. Generally you need to paste unformatted and then reformat in Lectora. To paste unformatted, either Ctrl+Shift+V or Right click and select Paste Unformatted. If you are copying a LOT of text, it might be easier to first copy and paste into NotePad. Also, it saves time to remove the bullets and numbering before copying from the source text.
