Hotspot in irregular shape- HELP!
January 21, 2009 12:00 AM
HConfer wrote:
Forgive me if I'm wrong, but can't you tie an action directly to that image? Instead of having a hot spot over it? You can, but Lectora seems to work only in rectangles. So, if you have an image in the shape of a cross, then not only will the cross be a hotspot, but the four quadrants of dead space will also be a hotspot. I believe the only way to make a cross a hotspot is to create two transparent rectangles overlaid on the cross. But I'll be happy to be proved wrong. I'd love it, actually.Kevin
