Text alignment problem in Lectora
Hi there,
I always get this text alignment issue in Lectora, when I copy text from Word document and paste it in Lectora, sometimes the text will not aligned properly after it's being published. It looks ok in the run mode but after you published it, the text alignment will look different. I usually need to retype the text in Lectora or adjust the text field width to solve this problem.
What you see in the editing mode or run mode might not be the same after you publish it. This is the problem that i always have.
