Tab Order Problem
June 27, 2017 12:00 AM
At work we use version 11.3.2. I've tested the following in Debug and in Blackboard where we publish our SCORM projects. Since this is part of a test, I've blacked out all of the information that must remain secure.
This Test has six pages (situations), each of which is composed of a background form and text entry box (TEB) questions on top. There are also boxes displayed (form entry fields) for other fields on the form that do not have to be completed. In previous projects, I've had no problems setting things up so that the student could tab left-to-right in one row, then move to the next row and continue tabbing left-to-right.
It is not working this time (see row 2 in the table). When the student is in the field (s6_r1c7) and they tab, they end up skipping Q#72 and Q#73 (colored yellow in the example) and they land in the field (named s6_r2c3 and colored blue, not a question). Then when they hit tab again, they end up skipping Q#74, Q#75, and Q#76 (colored red) and they land in the field (named s6_r2c7 and colored purple).
Why is this happening, any ideas? Any help/suggestions would be greatly appreciated.
Thanks, Maura
Discussion (2)
Unfortunately, as of January 30th, 2017 we no longer support Lectora version 11, vX, or earlier.
(More information on this policy can be found here: http://trivantis.com/support/end-life-notice-obsolete-software-versions/).
If you'd like, I can contact you with an account rep to get you information about upgrade options. Otherwise, you can wait for someone else running that version to provide support. With just a glance at your issue, I'd suggest looking at how the pages are arranged in the Title Explorer because that affects the tabbing order.
I have now upgraded at work to version 17, but still am having issues with Tab Order.
Anyone else have this problem?
