Where are you trying to save the video file to? Make sure that you have full access rights to the directory. The automatic file save property can be set from the file tab in the recorder settings. If this option is selected make sure your output folder is in a location where you have read/write/delete access to the files.Where are you trying to save the video file to? Make sure that you have full access rights to the directory. The automatic file save property can be set from the file tab in the recorder settings. If this option is selected make sure your output folder is in a location where you have read/write/delete access to the files.
