SCORM completion
October 30, 2008 12:00 AM
I had exactly the same problem with our LMS (GeoLearning hosted on WebEx). I had to create an action on the last page that was On:Show Action:Modify Variable Target:AICC_Lesson_Status (this is a built-in variable) Value:completed Modification Type:Set Variable ContentsThis sent the "completed" status to the LMS for me.You can also try the "AICC_Core_Lesson" variable if the other one doesn't work.
