Audio issues
Regarding Articulate:The output is swf and plays in a browser. I'm not sure if you meant that you were importing FLV's into Articulate or accessing them dynamically from the published SWF output.I agree that there are certain restrictions on running FLV content via a true webserver vs. running over a network drive. We have had this issue in the past regarding javascript code as well. is there a reason to NOT run the course via the webserver?
