Audio issues
What type of audio files are they? It may be an issue with the browser plug in for those particular audio file types. Maybe the browser is having issues with the codec, or compression, of the audio as it is not able to decompress the audio to play it. Are you using Lectora 2008 and if so, do you have compression enabled for the audio?What type of audio files are they? It may be an issue with the browser plug in for those particular audio file types. Maybe the browser is having issues with the codec, or compression, of the audio as it is not able to decompress the audio to play it. Are you using Lectora 2008 and if so, do you have compression enabled for the audio?
