Scoring Issue with Saba LMS
August 28, 2013 12:00 AM
I have Saba LMS. When I attached the SCORM 1.2 course from Snap to the LMS, the LMS is somehow seeing 75% as the default passing grade even though we had set the default passing grade to 20% in Snap quiz option.
I believe somewhere in the published SCORM files, it still has 75%... I just can’t locate it. Does anyone have any suggestions has to where I should try to find the 75%? I’ve tried just about all the files and did a Ctrl F and find 75 with no success.
Discussion (4)
@ssneg 55981 wrote:
Can you share the files? At least sample package?
PM sent. Thank you. Or what's your email address if you don't mind sharing here? Thanks again.
@Wee 55985 wrote:
PM sent. Thank you. Or what's your email address if you don't mind sharing here? Thanks again.ss@intea.lv
