Saving Problems
I'm having trouble with what is probably a very simple thing. At my job we have a directory set up called E-Learning with subdirectories for Lectora and Captivate. I'm trying to produce e-learning modules and put them in seperate directories in the Lectora sub directory but I can't seem to do it. In other words I want to have G:E-LearningLectoraLesson1, G:E-LearningLectoraLesson2, G:E-LearningLectoraLesson3 and so forth. Also if I change the name of thetitle using the properties dialog box when I save it and reopen it the name is changed in the title but not the blue band at the top of the screen.
I want to use a template to start a lesson then save successive lessons with new names as I create.
