Resetting Radio Box Within Question
What do you mean by the feedback reset? HG: I mean resetting the lines in a matching, the radio or check boxes in the other question types.You have to clear the question variable - Modify question variable and leave the Value field empty. HG: Yes. I know this. I did this and it doesn't reset the lines or checks. Even if I go to another page and back again.
