Question (not necessarily Test) Features
October 23, 2006 12:00 AM
Thanks for all the clarification. Really helps me (although I do not work for Lectora)Individual feedback for answer choices is available in some questions but like you say, it does not support immediate feedback. As to the retry, good idea. You can do that now with a bit of a workaround. Put a clear text box over the question answer area, initially not visible. Then make visible once they have submitted. Have a page action to make it visible if there is a value in the question variable. Your solution is better, this is just a workaround for today.
