Requiring users to click on objects
You can use 1 variable and add letters to it - one for each thing they have to click on. So if there are three things, add A to the variable using an action on the first object, B on the second, and C on the third. The next button has 3 conditions, does the variable contain A, contain B, and contain C. Make sure ALL is selected on the Conditions tab.You can use 1 variable and add letters to it - one for each thing they have to click on. So if there are three things, add A to the variable using an action on the first object, B on the second, and C on the third. The next button has 3 conditions, does the variable contain A, contain B, and contain C. Make sure ALL is selected on the Conditions tab.
