Recommendation for audio
We are going to be helping a group that has a bunch of courses set up as voice over Powerpoint (audio of the instructor presenting the slides). Does anyone have a recommendation about the best way to handle this to create a Lectora title.- Have the instructor create individual Flash files for each slide (that contains the audio and slide) (they use Camtasia to do this)- Import the slides into lectora (using Integrator) and then add an audio file (.mp3 or .wav) to each page.Is one of these methods a better approach (easier to develop, produces smaller filesize (MB))? or is there a better way?
