controller for flash
May 29, 2008 12:00 AM
Thanks Mark - The .swf files are actually recordings of an instructor presenting a powerpoint slide that were captured using Camtasia and then saved as .swf files....so I am not sure what version of flash it published to. If I look at the properties of the .swf file it says opens with Adobe flash player 9...not sure if that helps??And by height and width...do you mean the dimensions of flash file on the page. If so, that would be 640 wide x 420 high. However, I have a little area on the page where I would like the controller to go...and the dimensions of that area is 200 wide x 25 high.Not sure if that helped or not. Let me know.Thanks again!!
