It might be possible :) It really depends one how the .swf you are trying to control was built. If it is a timeline animation and the audio (assuming there is any) is set up to stream then it should work. I have one but I would need to change the dimensions to match the size of your file... Let me know it's height and width and I'll send it along so you can see if it works (oh also let me know what version of flash it is published to).
