Raptivity and Lectora - Help!
February 8, 2006 12:00 AM
Hi!I also used Raptivity and i could use it with Lectora. I found following instructions in some document which I got with Raptivity. Copying those straight here. Why don't you try these?Instructions:1. In Raptivity, ensure that interactivity is published with the option ‘Copy media assets under Publish folder’.2. Rename the published html output file to .txt file. (E.g. Rename “MyInteractivity.html” to “MyInteractivity.txt”)3. On Lectora page, add External HTML control.4. Select the checkbox ‘Use External Text File for custom HTML’.5. Click ‘Import’ button and browse the .txt file. (E.g. “MyInteractivity.txt”)6. Click ‘Additional files’ tab.7. Using ‘Add File’ button add all additional files (.jpeg, .swf, .dll, .js, .mp3 etc.) required to launch the html in the External HTML control. These additional files will be present on the same path where .txt file is present.8. Publish Lectora’s title using ‘Publish to HTML’ option.
