Solved
Ranking Question Not Functioning
I have come across an issue and have no clue how to fix it. I have a quiz built with 3 questions, two ranking and one multiple choice. If you answer all 3 questions correctly, it moves you to the next page (as intended). However, if you answer one of the ranking questions incorrect, it brings you to a knowledge check page (intended) but adds in the multiple choice question as correct as well, even though it has been answered correctly. I have tried to rebuild the question page and the knowledge check page and still the same issue. I tried to re-create the ranking question and move to matching and still doesn’t work.
Solution
I was able to resolve the issue. Turned out the text box on the knowledge check page was not set to initially hidden.
Discussion (2)
Hi Donna, would it possible to get a copy of your project (can be stripped down to just the quiz and knowledge check page, what ever is needed to get this behavior)? Testing with the Test Results, when I answer a ranking question incorrectly the MC question is shown as correct, so if possible I'd like to test this with your project
