Progress Bar Problem
January 21, 2009 12:00 AM
Thanks Ben. Yes, definitely. I need more help. As I am not much familiar with variables. I'm not getting exactly what you are trying to convey. I've used a custom bar and using the timer action is able to run it. but for the later part, I need a bit more elaboration.Thanks Ben. Yes, definitely. I need more help. As I am not much familiar with variables. I'm not getting exactly what you are trying to convey. I've used a custom bar and using the timer action is able to run it. but for the later part, I need a bit more elaboration.
