Audio Problem In HTML Publishing
I found a way for my replay button to work. Here's what I did:
I have a pause button initially visible, if clicked, first pause audio, then show play button (which is the same audio)
Then if click on the play button (the audio) it will play the audio.
And here's what I set the audio (play button) actions to do in order: On click hide audio, play audio, show pause, and then done playing show audio
Hopefully this will help someone. Thanks.
