Problems converting Lectora to Adobe PDF
April 18, 2009 12:00 AM
I forget who originally posted it, but the solution below has worked for me.
1. On the Print Window that opens, select the Adobe PDF printer. 2. Select properties and uncheck the "Do Not Send Fonts to Adobe PDF" check box.
Click OK. 3. Select the Print to File option. 4. Select your page range. 5. Select your layout. Click OK. You will be prompted to select an output file name. Place the full path to the folder you want the file to be saved to and give the file name a .ps extension. When done printing, find your .ps file, open Adobe Acrobat and drop the .ps file into the Acrobat window when it opens. This will create the PDF of your Lesson.
The result is not as pretty as a typical PDF, but it is much faster than taking screen shots of every page.
