Problems converting Lectora to Adobe PDF
I have the same problem with my computer locking up when printing to Adobe Acrobat 8. Tried re-installing Acrobat and that fixed the problem for a short time, but for whatever reason it started locking up again. I found two solutions:
1) Printing to a postscript file does work. (Outlined in a prior post) Be sure to de-select the option for relying on system fonts only. Select High Quality Print for better looking documents.
2) You indicated that other software was not an option but I tried a free print driver called PrimoPDF and it works very well with no lockups. And it's FREE!! Or, in a business you can purchase a copy.
Either one should work for you. Good luck!
